iMac G5 20" Model A1145 Hard Drive Replacement
  1. iMac G5 20" Model A1145 Hard Drive Replacement, Access Door: step 1, image 1 of 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac G5 20" Model A1145 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 Hard Drive Replacement, Front Bezel: step 3, image 1 of 1
    • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
  4. iMac G5 20" Model A1145 Hard Drive Replacement: step 4, image 1 of 2 iMac G5 20" Model A1145 Hard Drive Replacement: step 4, image 2 of 2
    • Turn the computer over.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 20" Model A1145 Hard Drive Replacement: step 5, image 1 of 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 20" Model A1145 Hard Drive Replacement: step 6, image 1 of 3 iMac G5 20" Model A1145 Hard Drive Replacement: step 6, image 2 of 3 iMac G5 20" Model A1145 Hard Drive Replacement: step 6, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
  7. iMac G5 20" Model A1145 Hard Drive Replacement: step 7, image 1 of 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 20" Model A1145 Hard Drive Replacement: step 8, image 1 of 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
  9. iMac G5 20" Model A1145 Hard Drive Replacement: step 9, image 1 of 2 iMac G5 20" Model A1145 Hard Drive Replacement: step 9, image 2 of 2
    • Disconnect both the camera and microphone cables.
  10. iMac G5 20" Model A1145 Hard Drive Replacement, Lower EMI Shield: step 10, image 1 of 1
    • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
    • It is not necessary to peel the lower EMI shield off the display.
  11. iMac G5 20" Model A1145 Hard Drive Replacement: step 11, image 1 of 1
    • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
  12. iMac G5 20" Model A1145 Hard Drive Replacement, Display: step 12, image 1 of 1
    • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
  13. iMac G5 20" Model A1145 Hard Drive Replacement: step 13, image 1 of 1
    • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
  14. iMac G5 20" Model A1145 Hard Drive Replacement: step 14, image 1 of 1
    • Peel back the two EMI tape strips from the left and right edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  15. iMac G5 20" Model A1145 Hard Drive Replacement: step 15, image 1 of 2 iMac G5 20" Model A1145 Hard Drive Replacement: step 15, image 2 of 2
    • Remove the four recessed T10 Torx screws securing the display to the rear case.
    • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
  16. iMac G5 20" Model A1145 Hard Drive Replacement: step 16, image 1 of 1
    • Lift the lower edge of the display slightly out of the rear case.
    • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
  17. iMac G5 20" Model A1145 Hard Drive Replacement: step 17, image 1 of 1
    • Lift the display until it is nearly perpendicular to the rear case.
    • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
  18. iMac G5 20" Model A1145 Hard Drive Replacement: step 18, image 1 of 1
    • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
  19. iMac G5 20" Model A1145 Hard Drive Replacement, Hard Drive: step 19, image 1 of 1
    • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of your iMac.
  20. iMac G5 20" Model A1145 Hard Drive Replacement: step 20, image 1 of 1
    • Remove the two T10 Torx screws securing the hard drive bracket to the inverter.
  21. iMac G5 20" Model A1145 Hard Drive Replacement: step 21, image 1 of 1
    • Lift the left edge of the hard drive slightly, then pull it toward the left edge of the iMac.
    • When reinstalling your hard drive, make sure not to push the rubber grommets through the chassis with the hard drive mounting pins as retrieving them may require removing the logic board.
  22. iMac G5 20" Model A1145 Hard Drive Replacement: step 22, image 1 of 1
    • Rotate the hard drive out of the rear case.
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
  23. iMac G5 20" Model A1145 Hard Drive Replacement: step 23, image 1 of 1
    • Disconnect the SATA power cable by pulling its connector away from the hard drive.
    • Remove the hard drive from the iMac.
  24. iMac G5 20" Model A1145 Hard Drive Replacement, Hard Drive: step 24, image 1 of 2 iMac G5 20" Model A1145 Hard Drive Replacement, Hard Drive: step 24, image 2 of 2
    • Remove the two T8 Torx screws securing the hard drive bracket to the connector side of the hard drive.
    • Remove the hard drive bracket.
  25. iMac G5 20" Model A1145 Hard Drive Replacement: step 25, image 1 of 1
    • Remove the two T8 Torx pins from the side of the hard drive.
  26. iMac G5 20" Model A1145 Hard Drive Replacement: step 26, image 1 of 1
    • Use the flat end of a spudger to pry the hard drive thermal sensor off the adhesive securing it to the hard drive.
133 other people completed this guide.
4 Guide Comments
Step 15
When I removed the 4 screws, my bit wasn't magnetic enough to pick them out and they fell in. I could only find 2 of them. Luckily, I was only using this guide to help me remove the hard drive before I recycled my old computer. Make sure to have a strong magnetic bit!
Ruth - Reply
if feels great to know there is people like you that instract and others really understand thanks for your help
JESSICA - Reply
Awesome instructable!
Mike Kurtz - Reply
Used this same guide to replace the HDD on an A1207 iMac.
Almost identical except for the positioning of the display cable which is on the right hand side of the logic board.
Only problem was the four Torx screws holding in the display. They are so deeply recessed that I had to buy a set of Torx wrenches with long shafts as the Torx heads in the iFixit kit I have are too short.
Good guide.
nzsteelersfan - Reply
Past 24 Hours: 12
Past 7 Days: 51
Past 30 Days: 162
All Time: 138,055
